2005 F150 issue with no idle change after tune
mikewells1974
2005 F150 5.4L , 4x4 , bone stock
Purchased New i3 Platinum #8145 - Updated Ignition Software (on Windows) - SN: 202799123
No changes to idle RPMs after installing 87 DiabloTune.
Installed Advanced Tune / Modify Parameters / Set Idle to 650-700 RPMs in Neutral & Drive / Removed Speed Limiter
Tune seems to install correctly & back-up file created/exported. No error statements.
Tried to update again, none available..
Warm Idle remains at +/- 500 RPMs..
New Tuner.
Cleaned MAF & TB , checked & found no vacuum leaks / Idle re-learn process.
Been a headache so far..
Please Help !
Thank you !
New Tuner.
Please Help !
Thank you !
Re: 2005 F150 issue with no idle change after tune
can you attach the last tune written file from the tunes folder here so we can take a look at the file?
mikewells1974
Thank you for the help !
thanks we're checking it out.
mikewells1974
The last tune attempt was with the aftermarket head unit unplugged , had read where it may cause issues.
(I stated bone stock earlier , head unit & SWC are the only mods , both disconnected).
Would the KAM cause an issue?
Wondering if installing with the door open would be best , so to keep the KAM off during ignition switch cycles.
Thanks again for the help
the aftermarket radios are not often an issue on Fords, mostly early GM trucks.
KAM wont be an issue, but keeping the door open is always a good idea when flashing.
mikewells1974
Any updates on the issue?
Yes, we confirmed the params are not working and the cal team is working on a fix, should be an update this week i hope
mikewells1974
Sounds great !
I really appreciate you guys.
Thanks again !
Thanks again !
mikewells1974
Hey Mike. Any updates?
Is the issue with the tuner itself? Would a different tuner have the same issue?
I have another i3 Platinum 8145 still sealed in the box. (accidentally two were purchased..)
I started to try the other tuner a couple weeks ago, but did not want to break the seal.
Any info or help would be great.
Thanks.
Thanks.
mikewells1974
Thanks.
Thanks.
its a firmware issue, it will be fixed in an update.
mikewells1974
10-4
Didn't mean to double-post..
Thank you.
Thank you.
mikewells1974
Good day Mike.
Any update on the issue ?
Thanks.
Thanks.
confirming with the team.
