2005 F150 issue with no idle change after tune
mikewells1974
Post by mikewells1974 »
2005 F150 5.4L , 4x4 , bone stock
Purchased New i3 Platinum #8145 - Updated Ignition Software (on Windows) - SN: 202799123
No changes to idle RPMs after installing 87 DiabloTune.
Installed Advanced Tune / Modify Parameters / Set Idle to 650-700 RPMs in Neutral & Drive / Removed Speed Limiter
Tune seems to install correctly & back-up file created/exported. No error statements.
Tried to update again, none available..
Warm Idle remains at +/- 500 RPMs..
New Tuner.
Cleaned MAF & TB , checked & found no vacuum leaks / Idle re-learn process.
Been a headache so far..
Please Help !
Thank you !
Re: 2005 F150 issue with no idle change after tune
can you attach the last tune written file from the tunes folder here so we can take a look at the file?
mikewells1974
Thank you for the help !
thanks we're checking it out.
mikewells1974
The last tune attempt was with the aftermarket head unit unplugged , had read where it may cause issues.
(I stated bone stock earlier , head unit & SWC are the only mods , both disconnected).
Would the KAM cause an issue?
Wondering if installing with the door open would be best , so to keep the KAM off during ignition switch cycles.
Thanks again for the help ๐Ÿ˜Ž
the aftermarket radios are not often an issue on Fords, mostly early GM trucks.
KAM wont be an issue, but keeping the door open is always a good idea when flashing.
mikewells1974
Any updates on the issue?
Thanks ๐Ÿ‘
Yes, we confirmed the params are not working and the cal team is working on a fix, should be an update this week i hope ;)
mikewells1974
Sounds great ! ๐Ÿ‘
I really appreciate you guys. ๐Ÿ˜Ž
Thanks again !
mikewells1974
Hey Mike. Any updates?
Is the issue with the tuner itself? Would a different tuner have the same issue?
I have another i3 Platinum 8145 still sealed in the box. (accidentally two were purchased..)
I started to try the other tuner a couple weeks ago, but did not want to break the seal.
Any info or help would be great.
Thanks.
mikewells1974
Thanks.
its a firmware issue, it will be fixed in an update.
mikewells1974
10-4 ๐Ÿ‘
Didn't mean to double-post..
Thank you.
mikewells1974
Good day Mike.
Any update on the issue ?
Thanks.
confirming with the team.
Return to โ€œi2/i3 for Ford vehiclesโ€
