Attempt to update my Predator with latest software revision
Ok, when I tried to download from the link on this page, it would only save as a .php file. When I went to the downloads page on this website, it let me download it as a .crom file. So, I downloaded the 9r02 file and attempted to apply it. Same problem as with the 9r01 file. After applying it, it will not reboot and just has a blank screen. Not sure why the old 8r10 crom works and applies flawlessly and the new ones won't.
lazorrazor
OK, you must have an older tool that will not work with the newer file.
Please reload 8r10 and use that.
lazorrazor
I too can't get 9r02 to install properly
I used the alternate file version posted in this thread by Mike. Once the download completes my Predator Lightning reboots and then gives an error message "application missing". I can reinstall v8r9 just fine. My serial number is 2000012 toad-1114645118.
Don
Don
RE: I too can
8r9 will be that latest revision that you can use then.
RE: I too can
What am I loosing by not being able go beyond 8rx?mikel wrote:8r9 will be that latest revision that you can use then.
RE: I too can
I am having the same problem. I have an older unit myself. Is there any way to trade up to a newer unit?
