2009 Challenger - VE not working
ipsmotorsports
Post by ipsmotorsports »
I had an 09 Challenger R/T in the shop today and discovered on our dyno that the VE tables do not work in the software (they are there, but when changes are made the car does not respond) Luckily i needed a global fuel change, so I scaled the injectors until we get this figured out.
Any ideas?
Eric
Original.drg
Pulled file
(88.15 KiB) Downloaded 377 times
johan
RE: 2009 Challenger - VE not working
Post by johan »
I have not seen this, how did you verify that the ve tables did not work?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ipsmotorsports
I made a 20% change in the WOT cells and nothing changed. The only way to change fueling in the car was an injector scaling.
Eric
johan
Post by johan »
Did you make sure to increase the max ve scalar, i think it is at 1.15 stock so it will clip any value higher than that to 1.15.
Diablosport INC
ipsmotorsports
I'm showing 0.87 max VE stock, I did think of this though.... has me baffled
frcfed347
Post by frcfed347 »
any answers to this. I'm having the same issue..
latemodelracecraft
Post by latemodelracecraft »
Yes I am having the sam issues
