Cant get I2 to install to vehicle
majesticmotorsports
Im trying to get a 2010 to install on a dodge magnum and when I select ez tune and 89 octane and use tune the circle stops and it doesn't do anything. If I go to advanced it wont let me get that far and everything is greyed out. I got a message one time that this vehicle isn't supported but when I try to run the updater it says there is no updates avaliable
Re: Cant get I2 to install to vehicle
Im emailing you an update to try, please save it to the i2 drive, let the tool import it then try again.
majesticmotorsports
I sent it a while ago to the email you are registered to, [email protected]majesticmotorsports wrote:[email protected]
resent to mike@
majesticmotorsports
it is .net not .com
I corrected it, it has been sent to both addresses.
majesticmotorsports
We still haven't received anything.. [email protected] or [email protected]
its a large file, it may be getting blocked on your end.
Too large for me to host it here on the forum, do you have a different email address?
majesticmotorsports
I tried to use a i1000 we had in stock and it has a error when trying to update pcm 04896405AQ and says to contact tech support
majesticmotorsports
you can try that one.
Last edited by majesticmotorsports on Fri Oct 23, 2015 10:50 am, edited 1 time in total.
was it a normal I-1000 or I-1000 dcx?majesticmotorsports wrote:I tried to use a i1000 we had in stock and it has a error when trying to update pcm 04896405AQ and says to contact tech support
Post the info file from that tool please.
sent...majesticmotorsports wrote:[email protected] you can try that one.
majesticmotorsports
got the email this time,, it is a i1000 dcx
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="0" sn="J2AI5E2-4"/>
<cal_id CM1="04896395AFke0r0" PCM="04896405AQ"/>
<restore bc="0" vin="2D4GV582X5H117299" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01u" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="2D4GV582X5H117299" oem="DCX" calid="04896405AQ"/>
<updates count="3"/>
<oem tool_oem="DIABLODCX"/>
<reg reg="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"/>
</tool_info>
-<tool_info>
</tool_info>
the dcx is for 11+ models, what year is this car?
